I have a project to mill a 1/2 inch deep 1/4 inch slot in aluminum. I have tried milling a shallow, 15 thousands, relatively fast, 20 ips at 1000 rpm. This works but it tends to clog the end of the mill. I did a small correcction cutting from the side of the cutter, this produced clean larger chips.
My question is: What is the most efficient way to cut aluminum? Is it to cut faster and thinner or slower and deeper?
Is this trial and error or is there a table?
Are fewer larger chips better or worse than more smaller ones?
Thanks, Dan
Thanks, Dan
