- Jun 21, 2021
- 139
wanting to try to make tool holders for the qc tool post. decided to try to make a holder that would mount to tool post and be adjustable up and down. making chips one photo shows the top of the tool holder . the small allen screw near the tool post is the vertical adjustment . one pic shows the piece with the cutter being run through twice with a height adjustment. the peice was also turned to about 45 deg. and run through with the cross slide. this project got long and took several 3 hour days.i think i could have carved it from a solid piece with a file just as quick. and at the end the drill press motor decided to growl and make bad smells.
