- Sep 24, 2012
- 498
I have a Little Machine Shop 3900 milling machine. Yesterday I did a small job that came out nicely, but I am certain that I could have done better. Basically, I had four pieces of 6105-T5 aluminum pre-made, but I wanted to remove some of, but not all, of a raised part, and I wanted to remove exactly the same amount from both sides, leaving the remaining raised part perfectly centered. Here is a picture of what I started with:
http://i1251.photobucket.com/albums...Project/IMG_0037_text added_3_zpsxuaphkza.jpg
So I fumbled around and tried to mill off exactly the same amount from the left side and the right side, of the "raised part" so that it would sit in the slot of the mating piece. It came out pretty nicely, but again, I know darned well there's a better way to do it. Here is my result:
http://i1251.photobucket.com/albums...t Project/IMG_0049_text added_zpsclrjacua.jpg
So my question really is this: how am I supposed to calculate the edge of the cutter I am using (in this case, I used a 5/8" four-flute cutter) so that I can use the little dial on the X-axis to go in exactly .218"? What I did, is I actually fired up the milling machine and slowly advanced the table along the X-axis until the cutter touched the work ....... then I stopped the machine and zeroed my X-axis dial. Then I figured out how many revolutions of the dial (3 complete revolutions of 60 thou = .180", plus .038" more = .218"). OK, but I didn't go the whole last .038" because I figured my initial zero point might be a bit off. Good thing I stopped short because sure enough I was off...so I just advanced the X-axis a couple thou at a time until my dial indicator told me I had cut enough.
Again - what's the right way to know that the edge of my cutter is at the edge of my work? Help! I'm making mountains out of molehills!
...Doug in Arizona
...Doug in Arizona
