- Feb 12, 2021
- 34
Afternoon everyone,
I'm working on a little project that got me wondering.
It's an adjustment screw for a rifle trigger.
The screwdriver slot in the end was factory machined to one side, and I went to turn it (with a small, precision bit screwdriver. No high torque applied here) and the one side of the slot busted off.
Luckily, it still long enough for me to flatten the top and file a new slot. It's my rifle, and the screw is totally hidden, so if it's not perfect it's not an issue.
But if it was a customer's rifle, I would want it as close to perfect as possible. That's part of the way I plan to build my business, by turning out exceptional quality work every time.
I have some problems with my hands from past damage. They slightly tremble often, and I can't hold small pieces with my left hand.
Anyways, to my question. Would a good quality mil, such as the PM-728Vt, which I plan to acquire be able to make a fine slot like this in such a small workpiece. It's 0.58" total length x 0.088" shaft diameter . I'm assuming it wouldn't be a problem, but knowing for certain will help me convince the wife that spending a few thousand dollars will be worth it. My original idea for the milling machine is to take out the human equation of using hand tools which my trembling would effect, as well as greatly expand the work I'm capable of tackling.
Sorry for the long winded post, but I wanted to properly explain.
Thanks for your time in advance,
Ken
Ken
