- Jul 28, 2017
- 2,565
I have a question about the best procedure for milling a piece that is relatively thin compared to its length. Specifically, a gib strip. I made one out of brass awhile back and ran into a warpage problem -- compounded by a poor work-holding decision. I DID expect some warpage due to manufacturing stress but made an apparently bad decision after I machined one of the long axes of the piece. I flipped the part over, re-installed it in the vise, and then (and here's where I think I made my mistake) I hammered the piece down and machined the other side. Well, when I removed it from the vise I found that it STILL was warped. I had to do a lot of screwing around to get it reasonably flat.
So my question is, what's the best way to deal with the built-in stress while machining? I understand that it probably isn't feasible to simply machine a piece and expect it to come out perfectly flat, but I'd like to minimize the work I need to do after doing the machining.
