I've got a 12" Craftsman and the accompanying milling attachment and I've found it quite useful for small projects. While I don't have the space for a mill, I wanted to see if I can improve on the utility of the milling attachment. The "vise" as it is just has the two screws to clamp down on parts. I know that there are supposed to be jaw pads that go between the screws and the work, but I don't have them. Regardless, the vise lacks a real dynamic jaw to hold parts on parallels or otherwise. I don't want to modify the current vise, but make it possible to mount another vise on there. Has anyone swapped out the vise on the milling attachment for something else?
I was thinking of using a 2-3" drill press vise or screwless grinding vise that I could make a counter-bore in the bottom of for the dovetail attachment. I could also make a steel plate with a hole in it to attach to the dovetail instead. The import grinding vises would be more than accurate enough for the work I do, but I'm concerned that they may be too hardened to effectively machine the bottom. The drill press vise has the benefit that they are mostly cast iron and probably much easier to machine.
I'd love to hear anyone's thoughts or ideas on this.
