- Sep 20, 2021
- 152
Now that I've had my bench top lathe for a while and am getting used to basic turning of various round stock - aluminum mostly, I miss the ability to mill flat surfaces on my work. Trying to weigh in my mind if I should buy a milling attachment for my lathe next, or if I should spring for a small-ish milling machine of approx same size. In retrospect I should have bought the JET combo with both mill and lathe - but listened to too many neysayers.
I'd like to be able to run a fly cutter type of operation to produce a smooth surface: approx. 3 inches wide, square a piece of rectangular stock, cut a key way for a shaft, make a hex bolt, etc.
My reservation about mini mills are same as mini-lathes: rigidity - seems that smaller units will may not be rigid enough, but I really don't want a full size Bridgeport knee mill (as much as I love 'em).
