- Jul 20, 2014
- 1,386
I have a small project where I need to cut a few angles, like making a toe clamp.
I've seen YT videos where machinists cut angles using the end of an EM instead of the side.
The cuts don't look very good this way. I'm thinking that using the side of the end mill would leave a better,
flatter finish., but this would necessitate put the work on an angle plate, bolted down, then cutting the angles
with the work upside down.
I don't have a sine plate, sine vise, rotating vise, or tilt table. I do have angle blocks and an angle plate with holes and slots that will fit in a vise.
Q: How are you cutting your angles? I don't want to tilt the mill head. I don't want to ruin the few pieces of O1 tool steel that I have for this project.
The angle cuts are 10°-30° on 1/4" thick stock. In order to use the side of the EM, the work needs to be elevated., which is why I'm thinking that bolting and clamping
to a slotted angle plate should do the trick. The cuts are 3/4" wide, so should I use a large end mill to make the cut in one pass?
