Howdy, I guess we all have to face this situation once in a while.
(Picture at bottom)
Particulars:
its a rifle rest base.
1" thick, 12" square Aluminum.
Mill table is 8 deep. (PM45)
Cutter: Glacern 45 face Mill. (new, and OMG I love it)
Desired outcome: visually appealing, and as best as possible flatness. whatever that really is.
So far: Moving clamps, and moving the piece, can mill the whole piece.
I understand the problem of moving a piece thats not really flat on the bottom, and also we have different clamping places. its a tough call in any event.
** having said all that, would love to hear of best case solutions, to just the above.
Now on to the second "thing".....
one surface is done. pretty good considering I think. But It needs hand-flat. I think. hehe.
Is this where I should be asking:
what drill mounted "wheels" would be usefull for taking just a little at a time, to blend in the few ridges here and there. they are a few thosuandths.
And in general, what drill mounted wheels woudl be usefull for starting, or finishing, a polishing of the Aluminum.
I say Drill-mounted, becuase....well, it seems with a 12" square its a bit much to present to a buffer setup ???
sorry lots of questions
here is a pic, if it helps. you can see I do have a gray Norton de-burring wheel. I am not adverse to files. you can see I started a little filing. but stopped, cause I might ruin it. lol.
- - - Updated - - -
of interesting note;
that starret rule (24") reads "flat and true" in the direction of the milling, and in the other direction, reads a high spot approx in the center.
(Picture at bottom)
Particulars:
- - - Updated - - -
