Here's a table mounted work stop I made about 18 years ago. At the time I was working alongside a couple mold makers, one of whom made many of his own tools, and they were works of art. His work inspired me to come up with this design.
The base is obvious, a big block of steel, counterbored hole for a 1/2" cap screw to secure to the table. The vertical rod fits into the base and is secured by the two cap screws on the side.
The block holding the 1/4" rod is two parts mirror imaged vertically, but for one being counterbored, the other threaded. Both are a very close fit on the vertical rod, and feature a half round groove for the 1/4" rod. Between the rod and the vertical cap screw, the two are relieved slightly creating a slight gap. When this screw is tightened, the two pieces pivot on the rod something like a clothespin, and thus wedge themselves on the vertical rod.
This has proven very solid and repeatable, and is quick and easy to adjust. It's a bit of overkill really, but I wanted to create something that looked nice and different, in addition to being functional.
