My Series 1 BP table is flat. I purchased a Chinese milling vise (rotates 180). Bolted to the table the top of the fixed jaw indicates in across the x axis at .000. This is 6" wide.
But when I indicate a parallel laying in the throat of the vise there is .005 from one side to the other. And the throat is where material bottoms out to me milled, so the top milled surface will be out the same .005.
Is shimming with brass or stainless stock a good fix?
If not what is the recommended correction? Will purchase a domestic vise in the future, but need to use this one at present.
Thanks, Richard
Thanks, Richard
