Mill vise jaw clamp/stop.......
brino
Confirmed Tool User
Staff member
H-M Lifetime Diamond Member
Jan 2, 2014
9,042
A few years back I picked up this 6" milling vise.
(.........and NO the battle scars were not caused by me, I got it used!)
I have wanted to build a jaw clamp and stop system that would allow removing the work-piece and putting it back in the same place.
Each jaw is just over 1/8" above the vise body.
I looked at a few different designs and builds and then came up with this.
It is made from 1" x 2" hot rolled steel.
I used 3/16" dowel pins for the sliders, a 1/4"-20 Socket-Head Cap Screw (SHCS) for the clamp bolt, a 3/16" shaft for the adjustable stop and a #10-32 set-screw for the brake. The brake also uses a small rod with a notch as the "brake shoe". It was something a I wanted to try and it works very well! With the set-screw just finger tight the stop rod is solid.
I'll be back in a few minutes with more photos...........stay tuned!
-brino
Nice work!
Here's just a bunch of photos showing how it's made.
The front:
the top:top.jpg
the bottom:
left end:
right end:
Here are the main parts:
The dowel pins were a tight fit into the fixed jaw, but got thread locker as well.
More to come.......
-brino
Here's the movable stop and brake/lock mechanism..........
and here it is installed on the vise:
The stop rod is far enough below the jaws to be out of the way of milling.
Since the front part with the stop rod is only ~0.300" thick the vise can still hold fairly thin work.
-brino
Looks great Brino!
Cheers
Martin
Great job Brino. I really like seeing projects where the builder has made their own designs and decisions on how to accomplish the goal. :encourage:
That’s an interesting scale there too, I don’t think I’ve ever seen one like it with different divisions like that. Pretty sure it would drive me nuts trying to remember what scale I was on but it sure looks intriguing!
-frank
The front:
the top:View attachment 340293
the bottom:
left end:
right end:
More to come.......
-brino
View attachment 340280View attachment 340281View attachment 340293View attachment 340294View attachment 340297View attachment 340298View attachment 340299View attachment 340300
I need to make one like that, it seems quite versatile. It would be easy to add an offset rod. I'll have you know that my mill vise has a mark near identical to yours but I am able to take full credit for the accomplishment ;)
Typically great work, Brino.
