WEBB 3HP with a 10x50 table,Mituyto digital readout, variable speed,found tool box with extra knobs,tools,manual etc inside of casting. I put paper towles between the pages of the manual and heated it up then pressed it in a vice. Worked pretty good. No one knew it was in there from new. The manual was in a plastic bag but still got part of it oil soaked. Owner purchased 2 mills and a lathe. He kept the lathe and a older Bridgeport mill (because it had the Bridgeport name). Way to nice,bigger and newer mill than what I needed or wanted. Told my wife it will keep it's value so when I'm gone, well you know. The only down part of this is, there is no accessories with it. I am now on the hunt of tooling and acc. Now I have to clean out shop and build my roto phase converter with everything else going on. Very busy at work and home.
