Mill info
lordbeezer
H-M Supporter - Silver Member
Sep 1, 2018
679
Anyone have info on this milling machine.i'm picking this up from a guy. He said it says Standard on it.have goggled without finding any info..hoping I can get more info from owner this week.thanksimage.jpeg
Hi Phil- looks interesting, I thought it was a Burke but no, that's not it. I see a motor there in the background, but I also see a fair amount of rust :)
that thing will keep you busy for a while
Mark
Motor and parts in back ground is off a delta drill press.mill has a 4 speed trans motor..little rust won't hurt anything
Kind of looks like my old Williams I used to have.288773I had a Kearny and Trecker vertical attachment mounted on mine
Cheers
Martin
The base and knee look a lot like these ones:
http://vintagemachinery.org/photoindex/detail.aspx?id=34544
http://vintagemachinery.org/photoindex/detail.aspx?id=31956
From "Standard Engineering Works"
http://vintagemachinery.org/mfgindex/detail.aspx?id=9421&tab=4
....but there's not much info except the above and this ad: http://vintagemachinery.org/mfgindex/imagedetail.aspx?id=15280
Please add some more pictures when you get a chance.
-brino
EDIT: I believe the ones I linked to are true "Hand Millers" with the table x-feed controlled by a lever. Meant for repetitive tasks.
Your photo however, seems to have a large knob at the end of the table, but also has the hole where the lever would go. Maybe upgraded over the last 100 years or so?
