Mill cooling fans inop.
Janderso
Jeff Anderson
H-M Platinum Supporter
Mar 26, 2018
8,765
How important is it to cool the variable speed head/belt? I run this mill anywhere from two minutes to a half hour on average.
Both cooling fans are on the fritz. One turns if I give it a push. The other does not work at all.
They run on 220 according to the manual.
This is a Sharp TMV 185TM. I assume they are the original fans since the mid 70's.
They look like computer cooling fans. Would be easy to replace I bet. If you have 220v you could look for 120v fans and run them from one leg of the 220v and a neutral.
Or just swap them for something like this:
It looks like a half… addition, can’t imagine that’s a factory deal. There’s a fan on top of the motor, ought to be adequate. I say they are unnecessary. And that’s a firm opinion. :)
Edit: They are in the manual? Hard to imagine that’s a real engineering solution. Bridgeports don’t have a problem or need for that.
Is the fan on the motor missing? If so just replace it (the fan.)
Well now that is interesting.
The user manual has them featured with a wiring schematic for 220 or 440.
They are factory for sure. This is a 3 HP head.
I’m thinking if in a production environment the head would heat up, this feature would be a nice addition. One faces in and the other blows out.
On the other hand, if Bridgeport variable belt drive heads don’t have them, I would agree, I may be just fine without them.
There are 4” 220 volt computer fans available for $20.
It just bothers me, I’m a freak when it comes to my machine tools. I want them to operate as designed. Yeah, they are used and they are old but they’re mine.
Those look exactly like mine
I could be important if you are running a VFD at low speeds. I have no idea if you are doing that....
Also, it is possible to lube the fans if they are needing it.
I just got a reply from Sharp Industries.
$179 for the set of cooling fans plus shipping.
I’m an idiot. These are bolt in ready replacements.
So why is my finger moving toward the order button? If I can retro $20 fans?
Decisions decisions.
I need to remember, I’m retired now. Fixed income and all………
I have a saying, if it ain’t stock, it ain’t sh#@$&#it!
You have machines! Buy the cheap fans, and make a bracket!
