- Aug 3, 2017
- 2,437
So, I had a problem last night that I ended up solving another way (just ran an endmill down it), but I found myself very surprised by the result! I had a piece of brass that I was boring out with a boring head. I got my top dimension about right (~.800), however when I pulled it out of the mill, the bottom was 50 thou smaller(~.750)!
I cannot for the life of me figure out how this could have happened! I was cutting fairly small passes, and in brass, and it seemed to be cutting the whole way. I wasn't particularly careful about placing the material (it needed to be somewhat straight, but even that was subjective), but I would think that would just result in a tilted hole.
I can only think the boring bar could deflect, but I don't see a reason why it would deflect further as the spindle came down (I used spindle feed to cut it). Any mis-alignment or problem with my mill I would think would just 'tilt' the hole instead of cutting a taper, so I've got no idea!
Thoughts?
Thoughts?
