Mig & plasma cart build...
FOMOGO
H-M Lifetime Diamond Member
Sep 2, 2013
5,409
Some commercial gym equipment that had been chopped up and put in a dumpster found it's way home with me, and had been sitting outside the shop for a year or better. The welding shop is getting a little crowded, so decided it was time to get some things off the floor, and a little more user friendly. First step was to get out the plasma cutter, and cut up the square tubing into more usable pieces. No drawings involved, just shooting from the hip as usual. I mean that's the way Sundance did it, right. Took a few measurements, and started sticking things together. The goal here like the work table, is to put this together for as close to zero cost as possible. I figure between consumables, paint, and the wheels, and casters that I picked up cheap a few years back, I should be able to keep the total cost to $30-40. Mike
IMG_20221022_124509799_HDR (1).jpgIMG_20221022_124515336_HDR.jpgIMG_20221022_145459813_HDR (1).jpgIMG_20221023_123541751_HDR.jpgIMG_20221024_172206126_HDR (1).jpgIMG_20221024_174836041_HDR.jpgIMG_20221024_183420547_HDR (1).jpg
Well done Mike.
Sidebar question: what do you think of the Toughhorse sawhorses?
I really like them, they get used a lot. Really strong, and fold up easily to stow away.
Thanks Mike!
A little further along. A little slice and dice on the drawer as it was about 6" to long. A lot of fiddling around with nylon rollers from another drawer assembly, and cutting and welding them together on a new rail without melting them. Did destroy one. welding on the thin stuff was going so well got a little carried away, and the next thing you know you have a pool of melted plastic. When finished, the drawer slides in and out smoothly, so all's well that ends up in the well, or something like that. The diamond plate top is the cover off a restaurant style grease trap that I pulled out when doing some remodel work. Welded in two pieces of 1/8th x 3" strap on either side to cover the slides, and for mounting the cable holders. Mike
IMG_20221030_143414164_HDR.jpgIMG_20221030_171836809_HDR.jpgIMG_20221030_171847449_HDR.jpgIMG_20221030_174335727_HDR.jpgIMG_20221103_160015908_HDR.jpgIMG_20221103_160100839_HDR.jpg
Finished up the welding. Ended up having to move the rear wheels back for better balance. It would have worked as was, but it just wasn't right. came up with a simple retention setup for the bottle. Formed the band right on the tank, and used some thick wall tubing, the same stuff I made the cable/torch hangers from, to make bushings for the pull pins. Built a box out of 3" strap material for wire brushes, tip cleaners/cutters, and other often used things. Now just need to clean everything up and paint. Mike
Finally got around to getting the cart painted, and finished up. The most expensive component in the build was the two cans of black hammer tone spray paint which ran $30. Wasn't it just yesterday that spray paint was $5 a can or less? Could have used something that I had on hand, but I wanted that finish. Anywho, one more project scratched off the list. Cheers, Mike
IMG_20221121_164300025_HDR.jpgIMG_20221121_164312622_HDR.jpgIMG_20221121_174346680_HDR.jpgIMG_20221121_174359385_HDR.jpgIMG_20221121_174414041_HDR.jpg
MacGyver ain't got nuthin on You! Very nice job, You're dog went by so fast it was blur, Is that a "Texas Heeler"?
