- Feb 29, 2024
- 28
I broke this little gear that fits inside the D gear on the power feed gear train. My carriage got bound up and locked into position when I engaged the power feed. This was likely from burrs on a new part I installed in the carriage. This essentially crashed my gear train and instead of shearing the shear pin, this tiny gear broke. I plan to remake the gear but it doesn't appear to be made of mild steel like the larger gears are.
This is the second one I broke, the first was from legitimately crashing the carriage while I was starting to learn how to operate a lathe. I tried tig welding the first one I broke, but it doesn't weld right at all which makes me think it's not steel. Plus it's granular at where the part broke, almost like cast iron looks like when it fractures.
Does anyone know what this little gear is made of? I was thinking of making it in either A36 mild steel or 360 brass. Has anyone made one of these? Looks like I have a new side project to work on.
