Been poking at this for a bit and finally have the motors mock mounted so I thought I'd share the build. This is a HF X1 mill stripped down with both X and Y replaced with HG20 rails and ballscrews. The working area is ~260mm X, 150mm Y, and 240mm Z. The Z is a KR33 bolted onto the back of the original column (the column is reversed with the dovetail on the back now). Without much shimming it is running about .1mm over 300mm in the Z and the X and Y are < .03mm. The motor mounts are a bit funky since I wanted to allow for manual control via hand wheels. The Y mount in particular is funky but I ran a FEA simulation and I think it will be ok for the loads I'm planning. My first mockup will be using wimpy GT2 belt/pulley which are rated for ~1NM and may actually be good enough depending on the microstepping settings.
The weak links will be the belts, motor mounts, ball screw support mounts and spindle. I have not yet decided how to power it or how much motor I'll need since I think the column rigidity and spindle's ball bearings will limit the entire machine but I want to do some testing to validate that. I will likely also have a 2nd spindle mount for high speed. I hope that this will be able to take light cuts in steel with small end mills. AC bearings would be a great upgrade but I'm not sure they can fit in the stock spindle housing.
I'll be running grbl on Esp32 via Bart Dring's wonderful port. I plan on making my own board with 4 axis outputs which will connect to JMC 2HSS57-N closed loop controllers running at 48V.
If anyone has any questions feel free to ask!
