I have a question. The two clamping holes for the over arm support in my mfb's headstock a are threaded. Are all the headstocks like this or did someone do this at home? Thanks.
No, the holes should both be smooth bore. In each hole should be one M6-44 Lock, One M1-26 Rubber Spacer, two M6-45 Lock Sleeves and one 1/4"-20 x 2-1/2" square head bolt with threaded end out. Screwed onto the bolt should be an M1-47 Lock Handle.
