- Dec 22, 2016
- 3
I posted this in another thread then decided it's probably better on it's own.
I bought a G1550 back in March of 1994 and never attempted to cut a thread on it till today because the lead screw was off it this whole time (long story). So anyway, after putting it all back together, shimmed and adjusted etc. to have it completely functional the 3/4 x 16TPI thread I attempted to cut was a total mess. I just couldn't figure out what was happening. Then I measured the lead screw and found it wasn't a 16TPI as stated but rather a 1.5mm pitch. The labeling on the lathe and the manual lists the lead screw as a 16TPI but it isn't.
My Harbor Freight 7 x 12 has an actual 16TPI lead screw and this is how I know for sure the one on my G1550 is metric.
So I'm thinking that I could possibly get a lead screw along with the other required parts from a G4000 to use on this G1550 lathe. Does anyone know for sure if the 16TPI lead screw from a G4000 is actually a 16TPI.
Thank you.
Thank you.
