- Nov 28, 2013
- 197
This should be obvious. but...
(edit: it was obvious - I'm stupid)
I'm using LinuxCNC on a 6040 router and have something screwed up with the setup. it makes everything a little small.
I'd assumed since machine was sold in US, it has imperial lead screws. ... but maybe not.
5 mm/rev not the same as 5 revs/inch. So if i have a metric ball screw, I can't use inch machine units.
Can i simply correct the difference in my stepconf setup?
my thought would be to enter 25.4/5 or 5.08 where you enter revs/inch and then actually check the results.
