- Mar 3, 2017
- 796
I just got a bargain die, for a 1/4-32tpi application (oil fitting) that has been on my to-do list.
So, instead of a two-digit price after shipping, I paid small. Unfortunately, it's not a 1" circular die, it's 13/16" circular.
That's OK, I've got (one) die wrench that should work... Nope, doesn't fit. It's a metric thing.
Alas, measured outer diameter of the die is 0.775". Nominal diameter for this (13/16" :== 0.8125" ) is
ok for the clearance on my holder (0.818") and far exceeds the through diameter of the holder throat (0.774").
But a 0.775" die just will NOT clamp, or center, or even stay straight, in this holder.
So, maybe if I wrap some tape around it it'll fit the holder? Maybe? Well, no. It always cocks
sideways with any attempt on steel. With some care, I got a plastic rod to take a thread,
and it does fit my oil port (so I CAN plastic-plug against dirt intrusion).
After a close-fitting washer is fitted in the holder, the die at least is straight
(but not clamped securely).
Twenty millimeters is 0.7874", and apparently that's the intended die holder size.
Not available from most good industrial suppliers, but some clever soul has put the
right description on eBay, so... it'll be here in a month, two at most, from the Far East.
Checking the feedback, I find the following high praise: "ok quality".
The die seller didn't describe the OD. A photo is NOT enough data.
The holder was made with an open throat excessively over the through diameters to be expected.
The die wrench sellers in this country don't allow for metric sizes, only stock 13/16", 1", etc.
The buyer (me) didn't know what he was buying.
I'm sensing a non-abundance of common sense.
