I have recently been involved in several projects that, as most do, involve sawing metal, for me it is up to 1/2" plate and 2" shafting. My thoughts were that I wouldn't even attempt such work when I only had a hand held hacksaw. Things took an up turn when I purchased a "Saws-All" but even that has limitations. Approximately 6 years ago I was given a dual speed Delta wood/metal cutting band saw that really changed the scope of my projects.
I recently had a fabrication shop make cuts through some 5" drill stem with a 3/4" wall, a project that was too big for my band saw and the hoisting abilities. The deal started out by me agreeing to replace the shop's saw blade if it broke. Fortunately I knew a little about this material, so agreed. I am not sure about the metalurgy but I think it is similar to 1018, any way the shop"s saw cut through it like butter.
My only point is that we probably do not appreciate or give much thought to this step in our projects but for me it has certainly been a great addition to my shop.
Ray
Ray
