Sold by MSC, also do an eBay search for "insert dpmt" and you find many listings. FYI, it is not uncommon for manufactures to have proprietary inserts, and when they discontinue the model you are stuck with a door stop.
DPGT is just a tighter tolerance than DPMT. Which in turn usually means sharper edges because they're often ground to achieve said tighter tolerances. Should work fine, might not be as robust, but will probably be better for light cuts and aluminum.
