I was looking at the form cutters designed for this, that does make this fairly easy for the angles. I already have 45 degree cutters, so it would be nice to use those instead of getting new tooling. I watched a video of a guy using the Picatinny cutterto make the rail, but he just moved over from the center axis the required dimension and cut one side, then moved over and cut the other side. He didn’t measure anything, so I was wondering how you could verify you went far enough with cutting the first side instead of relying on your calculations. A thought just came to me, since it cuts the recess below the angled part at the same time, you could probably measure that distance from the edge to see if you went the proper depth, and then measure the width after the final cut.
I have a surface plate, height gage, depth mics, mics, pin gages, but don’t have gage blocks or a sine bar yet. I wasn’t even thinking of the grooves in the top yet, I will probably need to get something for that even if it is just go / no-go blocks.
This is the gage I found that can be used to check once finished that I mentioned above.
This picatinny rail gauge is certified to be in picatinny spec. It is measured with gauge pins, gauge blocks, and a keyence microscope to ensure the tightest tolerances. Instructions:This gauge allows you to check if your picatinny is within +/-.002" of p
www.egwguns.com
Thanks for the ideas, I’m probably over thinking this, so when this project gets further along, I’ll have to experiment some and see what I can do with what I have and then look at the form cutter.
