- Jul 22, 2019
- 19
Backlash compensation (Yes - you should try to get rid of all backlash but....)
Neat video. Would you care to repeat your trial on a pocket instead of a boss?
Ancient history - I tried backlash comp to get better part tolerance on my Excello. My findings - if I adjusted it to get in spec on boss cutting, it made pocket cutting worse. I was doing one inch squares on both with a 1/4" endmill and making the machine work by removing a healthy cut, then a second pass with a light cut. Goal here was to simulate actual machining.
My conclusion, backlash comes from many sources, not just the ballscrews. its far more complex.
I am about to get my new Vectrax mill running. I'd like to understand this better to see if improvements are possible.
