The high school robotics team where I’m a mentor was gifted a Maximat7 by the local University. It’s in mostly good, but somewhat neglected shape. We were told that it was all working when last used. But we don’t really know when that was.
Liberal application of contact cleaner got the switches working. Some 3D printed parts means we don’t have to use pliers and hammers to operate the switches.
The two plastic gears in the train to drive the lead screw were in kit form, so I made new ones from Delrin. (First gears I ever made. You Hoo for my Sherline!) Now the gears will run in forward or reverse. Sadly, the lead screw doesn’t move. I suspect the pin that holds the lead screw to the last gear has broken. Possibly because any grease in the system has long since petrified. Does anyone know what that pin is supposed to be made of? The parts list I found online describes it as a bushing, but it clearly isn’t. I don’t want to replace something sacrificial with something too strong.
When I take it apart to find the broken part I’ll also clean out the ancient grease. What kind of grease should I replace it with? Also there are multiple grease points described in the manual, I assume they all take the same type of grease. Is there any special tool required to squirt the grease in, or just any old cheapie from Hazard Fraught? Perhaps some special tip?
I wish I had more time to play with it, but there’s a local competition in three weeks and the big worldwide competition starts in January. Still, we survived 10 years without a lathe, so one more won’t kill us. I already had one of the girls using it to centre drill and tap a shaft, so we’re ahead of the game already.
Thanks,
Brian
Thanks,
Brian
