Hey guys, I just picked up my first lathe and its a Maximat v10p.
Forgive me as I am a complete noob at machining so I am not very familiar with terms etc yet with lathes
Anyway I'm looking to upgrade the tool holder (the one that came with is is just a triangle clamp that is mounted to the post/bolt) to a quick change type but it looks like most available use a t-nut to attach the holder to the compound slide. The model I have has a single post/bolt coming up from the compound and is flared out at the bottom.
Does anyone know an out of the box quick change post that would work? Or would most kits require some machining to work with the V10p?
Another option I found was a seller in europe who has a used quick change set up advertised as being for the maximat v10 lathe.
I don't plan on doing any heavy machine work on the lathe, I am a knife maker and will most likely just be doing light pivot work.
Any help would be greatly appreciated!
