Map gas is a large component of green freeze refrigerant. Ditto for propane.
If its under pressure, and you reduce it's pressure, poof, you've got an a/c unit!
If it was warm out, and you had the bottle opened up a lot... It'll get cold.
As long as the valve doesn't freeze open (been there, done that!), you're good to go.
