- Aug 23, 2024
- 22
Had a need for a bunch of tiny brass washers, 3mmOD, 0.012 in thick. Tried holding brass tubing vertical, bring in .032" thick slitting saw. Every time one is sawed off, it flips up, leaving a nasty burr on bottom side, pain inna tail to remove nicely. Got the grey matter churning, found a good solution...imbed the tube in soft plastic (cheapo cutting board, maybe polyethylene), then saw through the plastic and brass. Raised the knee 0.0470 in/each washer. Tube is .118 in dia (3mm), drilled a .116 in hole in side of plastic, then easily shoved the tube (end rounded ever so slightly) down a few inches with the mill quill.
