I recently purchased a South Bend 13" CL145B lathe. It's moderately worn for its age (1954) and came from a school, so it's got scars all over it and a few broken & missing pieces, as well as a garish bright blue paint job, inexpertly applied.
The two pieces I need to repair/replace are one missing handle/plunger from the gear box shifters, and the carriage lock.
The carriage lock should be fairly simple, but a little tricky to measure what I need to make, so a diagram showing the part would be very helpful.
The handle/plunger seemed like it would be easy as I have a good one to work from, however I'm not sure how to disassemble the good one! It's not clear how it went together in the first place, it looks a bit like the knurled handle knob was press-fit onto the plunger shaft. I gave the exposed end of the shaft a few experimental taps with a hammer and it proved to be very soft steel, it started deforming and didn't budge so I stopped. If it's threaded on, it's on there pretty solidly and didn't budge with moderate force. It won't just pull off the tumbler shifter assembly, and I don't want to damage the spring inside with excess force.
Does anyone have a good exploded diagram of how these fit together, or pictures of one disassembled?
Thank you!
Thank you!
