Making Mini Rotary Table T Nutz: Ammco 7" Shaper
Ulma Doctor
Infinitely Curious
Feb 2, 2013
3,916
i want to make some T nuts for my shaper's rotary table
86M4Impm3OQjqI6H7VlKQFvzB52eejK6_3rCdIEu7kPLyydOFaapVUqWGj8x67NRaw7yMfYkZg=w533-h393-no.jpg
I thought for a first project to plane a piece of aluminum on 5 sides.
(i planed 5 sides because one side was milled flat on a vertical mill)
i was successful at making a rectangle.
it is the uncut diamond!
(the milled side is show facing up)
after some initial layout, i mounted the billet in the vise.
i started the shaper, taking light cuts and simply enjoying the click, click, and the watching sweet little curls pile upon the concrete.
here is the t roughed out.
the area marked in black will be a second set of t nuts
thanks for looking!
i managed to do some more work today on the T Nutz.
using a lathe parting tool to start hogging out the t nut from it's billet
then i rotated the billet 90* and started the parting process again.
live action shot of the parting op
AuKfrWxqw_gFHhKM2VAv9LCegPwqJbC4Jr-TkZwj5BHZJqWU15UnUvuLA53pUG_Ki_2A_CcO0A=w400-h534-no.jpg
the t nut is free, but needs some tuning!
here is the billet and the t nut before further refining
the finished blank:
next up:
drilling and tapping to #8-32.
i'll be able to render 4 t nuts from this piece.
each t nut will be 5/8" long
and some more work done!
the blank is fitted, drilled to #29 and tapped to #8-32.
here is a shot of the t nut blank in the rotary table
in the next act,
i'll be parting the nuts from each other!
Sweet! Nicely done Mike. Did you separate them using the shaper?
Thank you very much Randall,
i had delusions of grandeur in parting the t nuts with the shaper,
then i was stricken by the reality that i miscalculated the distances between the tapped holes and had to go thin blade to reduce the error :bang head:
if you look closely at the nuts you'll see center of the 8/32 is off by .020"in length- oh well!
i could have ground down a tool to do it on the shaper, but i chose to use a hacksaw and files to finish this go around
here is the kicker, i saw a hacksaw attachment that was homebrewed. :idea: after i already did it.
it looked like it would work very well
i may just add the project for upcoming things!
