- Oct 4, 2016
- 7,164
I need to make 6 flat washers from bar stock. After I turn to diameter, face, then drill, it will get parted. The washer thickness needs to be a consistent .250. Would the super glue to a host bar work, or is there another trick I could use.
I'm thinking, once I get the parted face flat I could use the diamond plates to lap to final size.
