I have a HF mini-lathe and hoping to use it for cutting shallow groves (threads, basically) on the outside surface of PVC pipe. In these groves I'll wind 12 to 14 AWG copper wire to create inductors (coils for radio circuits). The groves should be less than or equal to 8 per inch (8 TPI or less). The HF mini-lathes coarsest thread ability is 12 TPI. I was able to set up the A,B,C and D gears to theoretically cut threads under 8 TPI but found out that is was not possible to do so because of the heavy load on the gears/motor due to a bunch of reasons including the friction in the lead screw bearings and the general lack of precision in the whole drive train.
Years ago a friend had a lathe capable of doing this operation and I finally was able to use the coil form that he made for me. The form is made from 3 inch sched 40 ( I think). With the mini-lathe I made plugs for each end so that it would be rotated within a frame. A roller runs alongside and tracks the wire to provide a variable tap point resulting in a variable inductor (in theory from about zero to 30 microhenries) The coil worked out extremely well and I'd like to make my own forms of various pitches, diameters and so forth depending on the application. I would not use 3 inch diameter pipe going forward. Only 2 inch or less.
Any suggestions would be greatly appreciated.
Best Regards
Pete (WB2UAQ)
Best Regards
Pete (WB2UAQ)
