I want to make something like a crow's-foot wrench for a 2" nut. It'll be about 5" overall length, made of 3/16 mild steel, and have a hole that I can put a 3/8 ratchet drive into. It doesn't have to apply a ton of force -- it's basically used to back off a locknut that's snugged up against another nut that keeps a shaft-packing snug. (The thing I'm working on looks something like this.
I can make a 2"-wide slot in my plate just fine, but at the top of the slot, I need to make two more sides, so that I get four out of six sides of a hexagon. I'm not at all sure how to do this on a milling machine that's manual. If it were 90 degree angles I needed to make, that'd be easy, but 120=degrees...I just don't know how to do that with the mill vise. (I can use the DRO to tell me when I've gotten to the correct location, and I can use a file to clean up the last bit of the corners....but moving the piece at an angle that's 60 degrees away from the prior direction of motion eludes me.)
Any help you can offer will be most welcome.
