Made some bolts with special heads to hold the head on my Cincy as two were broken, and the Gib Screw.
Wiring again next Saturday!
I didn't see any noticeable wear on the gears within the headstock. There is likely a way to measure for excessive wear. However, the spindle doesn't seem sloppy.
Regardless, the V-Belt pulleys each have large chips in them. I'm considering TIGing them and turning them. But might be easier just to make new!
I just watched the Tubalcain videos on making pulleys. I figure I can make them, once I get them off the spindles. It's been suggested I bake them at 400F as it someone likely used locktite.
My larger concern is the Gilmer pulley the smaller shows what I believe might be judged as significant wear, but more importantly there is about 1/8" of slop on the shaft.
Does anyone know of a video or "how to" for making a gear with teeth such as a Gilmer? The other 3 Gilmers seem to be in adequate condition.
I've got a Grizzly 6" vertical & horizontalrotarytable withdividing plates and a tailstock (http://cdn0.grizzly.com/manuals/h7527_m.pdf), and I still have my Rong Fu 30. However, I'm not sure how to do the calculations, do set up, use the dividing plates, choose and end mill.
I figure like everything else, by the time I make the sixth one it'll be close enough to work.
I accept criticism well. If a Gilmer is above my pay-grade please say so.
Thank you,
Daryl
MN
Thank you,
Daryl
MN
