- Aug 21, 2023
- 151
Slowly backing my 1914 Cadillac out of my garage a few weeks ago. It suddenly stop moving and looking over my shoulder I could see the axle popped the hubcap off and was protruding several inches.
The two axles on the left are spares for my 1910 Buick.. The two on the right are from this Cadillac
Broken end of axle I took out of housing. This was a replacement axle made long ago. And was made of mild steel. That's why it twisted.
The axles are floating and locked in place with brass hubcaps...
Underside showing massive two speed rear axle. Low range 3:66 to 1 and high range of 2.50:1..Shift on the fly
Cutting stock the axle stock on my vertical band saw. Pre-hard 4140 at 32 RC hardness
Turning to size OD on my lathe.. Between six-jaw chuck and live center/. Rather than using a steady rest, I simply took light cuts..
Getting out the old dividing head on my mill. Rather than making up a plate with a center to support the far end. I set up a V-Block with a strap across the top... Getting the correct height needed two sets of parallels and two pieces of paper. Then trued up all directions within a few thousands over the entire length...
Roughed in spline using 1/4" carbide cutter
With a piece of 4140 stock, I started to make the end piece of the axle. It will be doweled and welded to the shaft..
Drilling and boring hole to fit shaft..
Cut-off tool machine groove short depth
Then set up on my vertical band saw to finish the cut
Ready to machine driver lugs on OD
A 1/2" thick piece felt in the recessed area acts as an oil seal between the shaft and axle housing... Hundred year Old technology that works yet today...
Machining the notches that drive the wheel hub on my CNC Bed Mill. I mounted the end piece on a plate and clamped it in the 8" machine vise.
Roughing with 3/8" carbide end mill
Sharpened the inside corners with a smaller carbide mill
Machined a dome shape on the outside end to miss the hubcap. The dome was added for more cantact area from the axle to the end piece. That will be welded in place after dowels are put in..
End piece fit into axle hub.. The brass hubcap will hold the axle in place.
The axle has two ring and pinon gears. Ratios are high 3.66:1 and low 1.5:1
The spline ends of the axle shaft fit into the side gears. If you look close you can make out the spider gears.
Cadillac only used this two-speed rear axle in 1914 making the car quieter and to achieve higher speeds. In order compete with other makes with six cylinders engines. A design way ahead of the competition. However in 1915 Cadillac introduced their first V8 and dropped the two-speed rear axle...
Added two 5/16" dowel pins at the split of the end flange and axle shaft to lock it into place. Then TIG welding the outside end only on one of the flange to the axle.
Assemble the axles and first test drive.. All is good...
