On an upcoming project I need to make a 1.5" long slot in a 1.5" thick hunk of 6061 aluminum.
The bad news is I don't have the tooling yet for slotting.
The slot will be 3/16 wide x 1.5" long and 1.5" deep.
Ideas I have come up with are to use a sawzall with some kind of a Rube Goldberg guide jig thing to help keep the blade on track, then file to the final width. The width dimension isn't critical. It is a pinch type clamping device. bolts will go through the slot to squeeze it onto the post that the part will be attached to.
(No band saw, jig saw, die filer or anything like that. closest I can come is the sawzall.) My experience is that with sawzalls, they like to cut anywhere except where you want them too. Blades like to wander a bit when they cut too....
The other option I have is to make a keyway type slotter tool and do it on the lathe by ramming it with the carriage. I have seen youtube videos showing how this is done but, I'm not sure how well this will work on an inch and a half depth and length. I have infinite patience, so time factor doesn't concern me, as long as it produces the desired result. It seems that this method will produce the nicest cut, but again, I'm not too sure how well this will work given the dimensions of the slot.
Of the two options I have thought of, I like the second one the best but, I thought I would post it here and get opinions from the more experienced people here at Hobby Machinist before I destroy my hunk of 6061.
Thanks in advance for all of your help!
