- Sep 2, 2021
- 157
How does one create a "double D" slot in, say a sprocket hub? For example, the sprocket hub with double D slot slips over a shaft with opposing flats and gets clamped against a flange with a bolt. I've had to do this before (hobby work) and it involved a lot of drilling and filing. I don't have punch capability, nor linear broaching. But I'm wondering if rotary broaching into a 1/2" thick hub would created said hole shape? A rotary broach may be in my future if it can be made to do this. The diameter of the shaft with opposing flats would be 1/2". I would use the rotary broach to "punch" a square hole in another bushing for a different application. A quick search indicates that I can get the three rotary broach pieces, the head and two punches, for under $150. Granted it's not commercial duty quality, but almost affordable.
Perhaps there is a simple method I'm not familiar with to make these non-round holes.
DanK
DanK
