I picked up a used Milwaukee mag drill and I found it has a bit of visible runout which gets worse the farther you are away from the drill. The socket in this particular drill has a straight bore with two drive dogs. There is an adapter which mates with this socket and has a MT3 socket. I've ruled out the MT3 tooling by simply trying a known-good dead center. The drill sounds fine and I can't feel any wobble if I shake the tooling while in the drill.
The end of the MT3 is easy to test and it shows less than 0.0005" TIR. So I'm assuming that something along the works has an angular offset (H-M link, thanks RJ for that detailed post). The problem is either with the adapter, drill's socket, or internals (shaft, bearings).
I was thinking that I'd need to get a reading at the very top of the MT3 bore but my DTI cannot reach anywhere near that far. Are there other methods for testing or will I need a long-reach DTI?
I also want to run these same tests with the drill's straight bore; basically trying to rule things out in order before I have to pull the drill apart. The adapter looks in decent shape; no rust and socket feels clean, no burrs.
Here's a stock picture of the adapter:
