Made some 200mm boat cleats
Ed.
Aug 31, 2011
164
Made four 200mm cleats for the boat, got some more scrap stainless 316 steel to make these, had intended to make the top bar also out of 19mm bar but couldn't find any scrap anywhere, new price was about $100 so ended getting an offcut of some 16mm 316 plate for $15, cut out the strips and shaped them, turned up some short legs on the lathe, tigged them to the top plates then used my large vice to press them in to the base plate in which I drilled some slightly undersized holes, flipped them over and tigged the bottoms together, still need to give them a light sand and polish but otherwise good to go. Another thing done towards getting the boat into the water.
Strips cut out.jpg Baseplate about to be tigged IMG_0744.jpg Almost finished just need sanding and polishing IMG_0747.jpg
very cool
I bet the rest of the boat is killer with work like this.
