- Dec 31, 2010
- 937
The backlash on the Enco mill spindle and my battery powered Z axis DRO are ganging up on me in that the tool will drop 0.010-0.015" adjusting the next depth. The DRO then shows unusual numbers at this time as well, thus the holder. I have a strong imported magnet with holding screws in holes on each end and narrow enough to fit on the bracket at the bottom of the spindle. The hole to be used on the magnet is 0.384" so a 4" rod was turned to that diameter from a 0.625" rod long enough to make flats on one end that is drilled and tapped 1/4" 20 to hold the indicator. The plastic case has broken loose from the magnet so I am considering a screw through the sides to keep it together. Ultimately a metal case similar to the plastic will have to be made. Not sure if the imported magnet will withstand drilling and heavy side pressure.
Have a good day
Ray
Have a good day
Ray
