equals .0165 per 39.37 inches.0.42 mm/m
Per Starrett, Main level vials have graduations that are approximately 80-90 seconds or .005" per foot (0.42mm per meter)
Starrett' 98 Series levels are .005"/ft. Their 199 series level is .0005"/ft.Should that be .0005" per foot?
That's correct.equals .0165 per 39.37 inches.
If your Starrett level is 10 inches long, that would equal ,0042 in 10 inches. Someone please check my math.
The bottom line is that the 98 series is not good enough to precision level a machine tool such as a lathe, but is adequate to level such as milling machines, drilling machines, etc.Starrett' 98 Series levels are .005"/ft. Their 199 series level is .0005"/ft.
Thats good enough for checking for twist i a lathe bed as well as levelimg, let it sit in use and see if it holds tolerances or check with a 199 Starrett or a King gage.The bottom line is that the 98 series is not good enough to precision level a machine tool such as a lathe, but is adequate to level such as milling machines, drilling machines, etc.
