That video has been site disabled. It can only be viewed on You Tube.
Machinist Buttons are used in center finding and layout worn. I will see if I can find something on them for you. Their official name is "Tool Makers Buttons"
"Billy G"
I thought the video was done very well too. What I don't understand is why the button needs to be adjustable if your layout is spot on.
A one piece button should work if your layout is good..right?
I'm still learning a lot in the machining realm, despite only having 4 years of HS machining some some 35+ years ago. I have been milling and turning on my own since 2001.
Any explanation would be appreciated.
Paco
Your method would add the error in locating the pin to that due to centering it.Thanks uncle h, I have so much to learn. It's seems the block the video showed would have been rotated and scribed on all four sides using the hight gauge indicating true center. Then a precise center pin (I don't know all the terminology) threaded in to aid in idicating on the four jaw chuck. I try to machine to +/- .0005 but always room for perfection.
I really appreciate this site.
