I am building a 'gear box' to drive an astorphotography camera mount. The shafts will be 6 mm steel set in ball bearings set in 3/8 aluminum plate. The large gears will be made of 1/4 aluminum discs with the gear teeth 2mm gt2 belt inside out. The small gears will be 2gt pulleys.
The forces will be small and the rotations very low, less then one rpm on all parts.
My question is: Is it reasonable to machine a close tolerance on the parts and then assemble them with loctite? If so which variant would be best?
