Hi folks,
A couple of months ago I picked up my first lathe, a 1948 Hercus 9a. It's a very close copy of the Southbend 9a.
The lathe is generally in good condition. One issue is that there is a significant amount of vibration coming from the countershaft. It's a 3/4 inch steel shaft running in cast iron blocks and has worn both the shaft and the blocks.
I've obtained bronze bushings and plan to sleeve the bearing blocks. My question is around the countershaft itself. If I machine a new one, does it need to be hardened? Do I use standard mild steel or something else?
Appreciate any assistance!
Thanks,
Joe
Thanks,
Joe
