- Jan 20, 2018
- 5,892
Machine shop/Gear shop closing!! - tools - by owner - sale
LFW Manufacturing, Inc. is officially closing. Leo Wickham has decided to retire this year and we are in the process of selling all of our equipment. This is a list of some of the machines and tools...
reno.craigslist.org
Machines Available
- Churchill Gear Hobber 36"
- Fellows Gear Shaper, 48" Type 6
- Fellows Gear Shaper, Type 6A
- Fellows Gear Shaper, Type 7A
- American Pacemaker- Lathe (48" swing) 72" between centers
-American Radial Arm Drill 4' Arm / 9" Column
-Axelson Lathe, 20" swing over cross side, 28" swing over bedways, 120" between centers
along with 3 steady rest and tool holder
-Monarch Lathe, 24" Swing x 82" centers
-Mattison Surface Grinder, magnetic table 12” x 36”
-Barber Coleman- Hob Sharpener, #540
-Cincinnati- Vertical Milling Machine #2, table size 12" x 57"
-Cincinnati- Vertical Milling Machine #3, table size 15" x 62"
-Cincinnati- Horizontal Milling Machine #4 table size 18" x 80"
-Lees Bradner Thread Mill and Tooling
-Gould & Eberhardt Gear Hobber, 24H
-Hobart 600-amp Welder & Wire Feeder
and (2) 50' Leads
-Thermal Dynamics- Plasma Torch, capacity 1" Aluminum
-Cross Gear Tooth Rounder
-Powered Welding Positioner, 34” Turntable
-Toss Gear Hobber, M03199 Model OF 32A
-Max Diameter 320 mm, Max Module 7mm, Hob head Travel 250mm
-Nelson TR-450A Solid- State Stud Welding System
-Hofmann (Germany) 24 3/4″ diameter milling rotary table
-Wellsaw bandsaw, 19" throat, and 10" height capacity
-SERVO CNC Vertoca; Milling Machine
-Rigig 535 Pipe Threader Threading Machine 1/8" to 2" with wheeled Cart
-Manual Steel Strapping Combination Machine tool with 3/4" Width
-Bench Grinder
-Steel strap banding machine with tools ( manual )
-Oil transfer cart
-LINCOLN IDEALARC MODEL R3R 400 ARC WELDER- 440/460V-Stick
