At a minimum, I divide the machine weight by the number of feet, then double the number to find the needed capacity. Sometimes I size the feet to each handle the machine weight. Depends on the shock load they might encounter. For a punch press I would at least double the machine weight for each foot. Each one of my mill feet will handle the entire weight of the machine, this was primarily determined by the bolt size of the feet mounting holes.
