Machine care for garage
Phils69
I am still in the process of buying a lathe and mill for the garage. I am concerned about the environment being conducive to rust. I frequently use the garage door so it will be hard to control the environment in there. A guy at work says that he lightly oils his and covers them when not in use. He also suggests a dehumidifier. Will this be adequate to prevent surface rust?
The thing that causes rust to form is warmer moist air hitting a colder steel/iron object, causing condensation.
Anything to keep it warm will keep it rust-free - a block heater, a light bulb underneath.
Another possibility is a dehumidifier.
During the summer, an air conditioner will dehumidify the air.
And of course, keep it oiled, but don't use automotive motor oil which has additives to absorb & emulsify water.
ATF is OK though. I use medium way oil for almost everything.
Yea he mentioned the light bulb thing too. I don't have a window on the garage so no ac. I've been looking at Craigslist and seen too many on there with rust. I want to avoid this for sure.
Both of my mills and both lathes have been in a South Central garage in the open air environment for the last 8 years. The have very little if any rust. But then again I manage to use each machine at least once every day. The oldest is a 10 year old bench drill press. It has some rust on the pole because the table doesn't get moved much.
Constant use of machining fluids helps.
I have my machines in a farm machinery shed. Big airy building. open eaves. Draughty. I just toss an old flannel sheet over my machines to help with rusting, or the prevention of anyway....Keep the air from settling on the cold steel.
Cheers Phil
I have a ceiling hung propane furnace that blows on my mill and when furnace is used in winter get l light rust/discoloration on my rotary table mounted on the mill. Wipes off easily with oily rag. Could be from moisture in the propane?
Like 12bolts said, "toss a flannel sheet over the lathe"
I perfer cotton canvas like heavy denim "Levi pants" material. Make sure everything stays oiled, not with WD-40, either, before draping sheet over your machinery. This also keeps all of the airborn particles from settling on your machine, too.
Got mine from over runs from a local cotton mill.
Sounds like you will need to keep your machines well oiled. My garage only has a small electric heater for getting the chill out of the air when its chilly out there.
I have tried the light bulb thing in the base of the machines, with no differance that I could see. Mybe a slight increase in hydro. Over the yrs, I have found the oil works best. I just use AW32 and a paint brush to apply it. Area,s that I dont want the oil dripping from, just wipe with a oil soaked rag.
If you can put up with oily machines, thats about the only way Ive found it effective. Heaters just cost to much to keep the machines warm, and if your opening the doors and letting the cold damp air in, heaters wont help much.
I did at one time use propane to heat the shop, but I found it was a very moist heat, and still needed to slim the machines up. Though Im not really fond of the slimed machines, it works very well. Rust I can not handle, at all. It makes for to much work to remove it, and I cant stand to look at rusted equipment. So oil soaked machines it is.
On a final note, dont forget to oil the spots you dont normally see, as they will rust too. Just dont use WD-40. It wont help with rust. It will only attract moisture and help things rust over the long haul.
Thanks for the help guys. Looks like they are going to be well oiled with drop cloths on them. Now if I could just find a good mill and lathe to buy to put this to the test.
Breakfree clp works great on the things you don't wan't real oiley. I use it on my guns and machines
